Discussion topic: Pop up on tv screen
Message posted on 07 Aug 2026 11:25 AM
Pop up on tv screen
Message posted on 07 Aug 2026 11:55 AM - last edited: 07 Aug 2026 11:58 AM
Re: Pop up on tv screen
Judge Judy is tracking you @daretobe12 🤣
Might be an error or perhaps a billing issue? Did you call the number?
You can unplug at the mains for 5 minutes to try and clear it but if it is a genuine billing issue, the message will return.
Edited to add:
Seems others have had similar, check this thread out.
sky Q 2 TB | sky Q Mini | sky Mobile | EE Full Works FTTC | LG B6 OLED | SONOS Beam 2
Message posted on 07 Aug 2026 02:22 PM
😆 🤣 maybe. Bill upto date so not that seems to do it on a couple of channels no idea why wondering if maybe channels going to change 🤔 not to bothered as only watch when nothing on. Thx though
