06 Sep 2023 12:56 PM
We have an issue with birds landing on the bar between the sky dish and the receiver, stopping the signal this happens several times a day stopping the signal to the tv
06 Sep 2023 01:04 PM
That isn't something Sky will deal with, although it might suggest a dish alignment issue which is within their remit.
An independent satellite dish installer or a competent handyperson could fit either purpose-built or DIY bird deterrence: this is usually some form of plastic 'spike' arrangement.
06 Sep 2023 01:06 PM
Posted by a Superuser, not a Sky employee. Find out more@Tony4 There isn't much Sky can do about nature, you could put some cable ties pointing upwards to stop the birds nesting on the arm
06 Sep 2023 01:08 PM
I am 65 years old, I can't get up on my roof, it 3 stories high
06 Sep 2023 01:09 PM
Sky won't go that high anyway. They won't go on roofs either. That might be an issue if you ever need dish maintenance.
06 Sep 2023 09:44 PM
Posted by a Superuser, not a Sky employee. Find out moreSuspect the fact it's on the roof is why birds are landing on it though I'm sure there's a good reason why it's up there.
07 Sep 2023 10:21 AM
@Tony4 wrote:I am 65 years old, I can't get up on my roof, it 3 stories high
I suggest you need to employ an independant satellite dish installer to come out (Sky won't work on a dish that high). An alternative to cable ties could be covering the whole dish & arm in a plastic pond net, this should not interfere with the signal; but the dish installer should be able too advise the best solution for your setup, the cost of which will be down to you.
