Discussion topic: Poor sky signal
Message posted on 06 Sep 2023 12:56 PM
Poor sky signal
We have an issue with birds landing on the bar between the sky dish and the receiver, stopping the signal this happens several times a day stopping the signal to the tv
Message posted on 06 Sep 2023 01:04 PM
Re: Poor sky signal
That isn't something Sky will deal with, although it might suggest a dish alignment issue which is within their remit.
An independent satellite dish installer or a competent handyperson could fit either purpose-built or DIY bird deterrence: this is usually some form of plastic 'spike' arrangement.
Message posted on 06 Sep 2023 01:06 PM
Re: Poor sky signal
@Tony4 There isn't much Sky can do about nature, you could put some cable ties pointing upwards to stop the birds nesting on the arm
Message posted on 06 Sep 2023 01:08 PM
Re: Poor sky signal
I am 65 years old, I can't get up on my roof, it 3 stories high
Message posted on 06 Sep 2023 01:09 PM
Re: Poor sky signal
Sky won't go that high anyway. They won't go on roofs either. That might be an issue if you ever need dish maintenance.
Message posted on 06 Sep 2023 09:44 PM
Re: Poor sky signal
Suspect the fact it's on the roof is why birds are landing on it though I'm sure there's a good reason why it's up there.
Message posted on 07 Sep 2023 10:21 AM
Re: Poor sky signal
@Tony4 wrote:I am 65 years old, I can't get up on my roof, it 3 stories high
I suggest you need to employ an independant satellite dish installer to come out (Sky won't work on a dish that high). An alternative to cable ties could be covering the whole dish & arm in a plastic pond net, this should not interfere with the signal; but the dish installer should be able too advise the best solution for your setup, the cost of which will be down to you.
