156
This discussion topic has been answered Discussion topic: Pause / rewind issue 16/09/25
Re: Unable to pause or rewind live TV
@JohnRankine wrote:
I have the same problem this morning as well, is the fault at Sky's end?
hi @JohnRankine
As you will see I have moved your post onto another discussing this - please see the reply currently marked as Answer to advise SKY are now aware
This message was authored by: Lotty10710
Thank you so much. I have now been able to pair the remote and dismiss the screen.
This message was authored by: Iangreaves67
Re: No live pause or recording on my sky channels but it is ok on bbc itv etc on my sky+hd box
Help with live pause
This message was authored by: Tonto123
sky q box unable to pause, rewind or record
my tv is working with my sky q box but i am unable to pause or rewind live tv. i am also unable to record.
This message was authored by: Emily147
Hi I am having the same issue. I ca no longer pause or rewind. How do I fix that?
@Iangreaves67
I have moved your post to the topic at hand where you can see the post from Sky (the one marked as the answer) to say there are aware of this issue are are investigating.
This message was authored by: Dove+Cottage
I have same problem live tv will not pause, a screen message says I cannot pause, rewind.
did sky q box reset then paired remote ok but still cannot pause live tv.
my LG remote pause button does exactly the same.
Sky q will not pause rewind Live tv
This message was authored by: TonyCod
Re: No Pause or Rewind???
I am having the same issue this morning, tried power down and also updating software but problem remains.
This message was authored by: PhilW888
Re: SkyQ Pause not working
So will you add further updates to this post when you have more info. on this issue?  I'm  unable to pause or rewind 101, 102, 103, 105, 203, 204, but can pause 104.
This message was authored by: Jon+Curtis
Re: Sky q will not pause rewind Live tv
I have same issue, tried re-booting sky q box and mini box but issue persists, maybe its a bigger issue up the line?
This message was authored by: LQ2
Live Pause not working on Sky +
Hi, i am not able to pause or rewind most channels on my Sky plus box this morning.  It was working yesterday.  I seem to be able to pause Gold channel ok.  The on screen message says to call the Broadcaster.  I followed the online instructions to rebuild the box but still not working.  I havent tried the full reset as i would lose all my recordings.  Is there anything else i can try?  My sky + box is old and i am only able to record certain certains as i lose the signal.  If i ring Sky what would they do?  WIll i have to do the full reset? Many thanks
Please also see this post stating that SKY are aware - you may wish to subscribe to that discussion so you receive updates
This message was authored by: Jenny+wwh
Yes getting the same problme here in Devon.
Done a reboot.
Pause / rewindo only worlking for recordings now.
Samsung TV - not that that shoudl make any difference..
This was definatly an overnight thing - so maybe a dodge update -
Software Version showing is
Q320.000.15.ooL (62axucc0
hardware version shhowing is
32B206
Answered - Go to Answer
