This discussion topic has been answered Discussion topic: Paramount+
Message posted on 13 Apr 2025 04:35 PM
Re: Paramount plus
Is this on Sky Q, Glass or Stream ?
Message posted on 13 Apr 2025 04:40 PM
Re: Paramount plus
Thanks , we keep trying this to no avail . It's getting really annoying as we want to watch Mobland .
Message posted on 13 Apr 2025 04:46 PM
Re: Paramount plus
Hi @PoshMichele
Assuming your Broadband Speed isn't the issue,
Message posted on 13 Apr 2025 05:53 PM
Re: Paramount plus
We are Sky Q
Message posted on 13 Apr 2025 07:23 PM
Re: Paramount+ issues
Exactly the same problem. I've updated software. Switch off and on both sky q box and internet box. Happens at 31 seconds left of second advert every time
Message posted on 14 Apr 2025 10:48 AM
We have been told in an update from Sky today in our closed community area this is still with Sky and Paramount working for a solution.
It is being actioned.
The same problem is occurring for Sky Glass and Stream customers;
As per the previous Sky status answered post in the thread for Sky Glass/Stream for the same issue;
Current status Answered post link on the Sky Glass and Stream issue thread
Message posted on 14 Apr 2025 10:52 AM
Re: Paramount+
Post marked as the answer to provide an immediate view of the latest update. It can obviously change in due course.
Message posted on 15 Apr 2025 09:07 PM
Paramount+ error 3005 sky Q
Paramount+ will stall on as breaks at 31seconds remaining then either display error code 3005 or skip to next episode.
It will then take up to half an hour going back and trying to continue watching the episode before it will work.
This has been going on for about 2 weeks now and it's very frustrating. Can someone recommend a fix
Message posted on 15 Apr 2025 09:38 PM
Re: Paramount+ error 3005 sky Q
No fix as it is being investigated as you can see here:
Message posted on 16 Apr 2025 07:32 AM - last edited: 16 Apr 2025 07:32 AM
Is this the issue @Numbnumb was talking about?
is this only on Stream?
edit: ah no I see it says Q as well on that thread.
Message posted on 16 Apr 2025 08:18 AM
See the answered post above for an answer from Sky re working on a fix.
Message posted on 16 Apr 2025 02:47 PM
Re: Paramount+
I have reported the issue to Paramount + and they're looking into it . I made them aware that I am not the only customer with this problem.
Message posted on 18 Apr 2025 08:50 AM
Re: Paramount + error code 3005
I'm having the same issue, it's impossible to watch anything. I've been onto Sky three times, once they updated Apps, that didn't work, then told me to play it on my phone for 15 minutes that worked but only until the next ads. I've phone Sky again and they said there is a known issue paramount are working on and havd been since 21st March. This affects Sky glass and Q. It's rubbish as basically Paramount is not currently usable and I only pay for Sky Movies to get paramount !!!
SKY, you need to sort this issue fast
Message posted on 18 Apr 2025 02:02 PM
@Samcam123 wrote:SKY, you need to sort this issue fast
...or, indeed, Paramount
Message posted on 23 Apr 2025 08:39 AM - last edited: 23 Apr 2025 08:40 AM
Re: Paramount+
Have noticed that this seems to have been fixed finally for me on my Sky Stream.
So hope it is now fixed for those of you on Sky Q having the same issue.
Watched the latest episode of Mobland and the last two episodes of 1923, without any problems.
Notice a few others are saying the same in the Sky Stream thread.
Hope it is now working for others here too.
