10
This discussion topic has been answered Discussion topic: Paramount plus upgrade
This message was authored by: laister
You can now upgrade your paramount plus account with Sky to either hd with no adverts for £3 per month or UHD without adverts for £6 per month. Only you can't!
If you try on your q box all you get is a fault code SKY2999.
You cannot upgrade on my Sky app.
Rang customer services today and they could not help me , saying it's a fault and they have no idea when I can upgrade.
So it looks like watching paramount plus with adverts for the foreseeable future as Sky not renowned for their technical abilities.
Did we not used to get this for free?
This message was authored by: Elainejo Answer
Re: Paramount plus upgrade
I have been trying to upgrade to Premium for £6 all I keep getting after putting my card details in is that there is a problem and quotes me a reference ive tried contacting sky they cant do anything they tell me. I have mine through Sky Cinema why offer these subscriptions if you cant access them adverts are so annoying and useless.
No, you had to subscribe to Sky Cinema.
However... The tier was reduced recently to that with adverts.  Personally, it doesn't bother me as most of the adverts seem to be for their own programmes...
This message was authored by: Snaggle+Puss
I'm just the same but my error message is 2306
Paramount plus are doing a deal if you want 4K it's half price for the year. That's cheaper than Sky all you need is a seperate Email  address. I now watch it via my smart TV HOPEFULLY  Sky will have it all sorted before I renew.......
This message was authored by: Richardr1
There's nothing to stop you using that other account on your Sky box if you like - all you need to do is sign out and then sign back in on the other account.
Sky Q 2TB box and one Minibox
Thankyou I've just done it - your a star
This message was authored by: MrGrumpy60
Same problem with me too 😞
This message was authored by: Sue13571
Great channel  love it
This message was authored by: Forestwalker
Just in the Sky upgrade screen (21/10/25) and Paramount+ is now £4.99 with ads or £7.99 ie. no difference to signing up direct 🤷‍♂️
Just decided to take the value route and signed up to Sky Cinema with Paramount for £10pm  apart from an error message and having to sign out of my Paramount account (I had the free 1 year trial) and back in all seems to be working. Seems to be the way to go with getting Cinema and Paramount for a tenner. Not impressed with e erything renewing for a 24 month contract nlbut that is normal these days.
Answered - Go to Answer
