Discussion topic: Paramount + Sky Subscription Problem
Message posted on 09 Dec 2025 01:49 PM
Re: Paramount + Sky Subscription Problem
Yes i have tried this but to no avail
Message posted on 31 Dec 2025 04:25 PM
Paramount will NOT accept my email
Message posted on 31 Dec 2025 04:35 PM
@ACI did you follow the instructions on the link below regarding creating an accountr
https://www.sky.com/help/articles/paramount-plus-homepage
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 02 Jan 2026 08:54 AM
I emailed a complaint in to Sky which was picked up by the Sky Streaming support team. They were able to fix the issue by removing Paramount+ Premium from my account 'in the backend'. I have Sky Cinema, so they also did something to re-associate my Paramount account with Sky so that I get Paramount+ Basic via Sky (which is included in Sky Cinema).
The option to switch to Paramount+ Premium via an app subscription on my Sky Stream is available again, although I haven't done this yet.
Message posted on 10 Jan 2026 04:52 PM
Hello
What email address did you use. I have this issue current says paramount+ premium renewal in progress then cancelled basic with ads. I have rang them since October they have cancelled cinema twice apparently they can't do anything and been told to just pay for paramount instead.
Message posted on 19 Jan 2026 07:27 AM
I have this similar thing just happen to me now with failed payments and access to to Paramount Plus
Message posted on 23 Jan 2026 09:47 PM
There is a solution to this problem. (I have Sky Stream, with Sky Ulitmate TV, with Cinima, and had a Standard Paramount+ subscription in the marketplace)
I've been able to get myself up and running again this evening.
I gave up with technical support as everything they suggested didn't work.
Here's what I ended up doing myself:
1. I spoke to someone from the cancellations team. I told them I wished to "cancel" my Paramount+ marketplace subscription. As the subscription was stuck in "renewal in progress" they were not able to help me straight away. They had to raise a CRF (customer resolution form) for me. This needed to be sent off to another team who would remove the subscription.
2. I keept an eye on the MySky app. After a day or so, my Paramount+ marketplace subscription was gone. No Standard, no basic, nothing. I checked on the TV also, and no marketplace subscriptions were showing up there either (there is a cancelled section and there were a few things in there, but mothing active, nothing with "renewal in progress").
3. I opened the Paramount+ app on the TV, and tried run through the setup process again....I scanned the QR code, and got the same error as before ("Your sky subscription has either expired or does not include Paramount+")
4. The following day, I tried again, only this time, I noticed that the Paraumount+ section in App Subscriptions in the MySky app now had an "activate" button. when I clicked it, my account was linked succesfully)
Following this, my Sky ID was linked with Paramount+ again, and I had the basic (with ads) plan.
I've not yet tried to upgrade to the Standard plan.
I'm not sure if my first attempt in step 3 didn't work because I tried it on the TV, and it only worked because I retried in the MySky app or if it worked because I retried the next day (or both).
I'm also not certain if these steps work by themselves or only as a result of having previously tried many things over the phone with Sky technical support over the last 3 months. When on the phone with Sky technical support they had previously removed and re-added Sky Cinema 3 times and gotten me to:
- Turn off the Sky Stream puck countless times
- Perform a reset of the Sky Stream puck
- Perform an "app refresh" on the Sky Stream Puck
- Create a new Sky ID, link it to my "primary" Sky ID, and try to link Parount+ with the new Sky ID
- Create a new Paramount+ account and try to link to that instead
- Change the email address on my Sky ID
- Delete and recreate my "primary" Sky ID
- Change my last name in my Sky ID
Sky also asked me to contact Paramount at least 5 times, insisting it was their fault. Who to their credit conducted some "profound verification" and concluded that it was definitely a Sky problem.
I hope this works for you. Do make sure that you insist Sky give you a refund for any months where you have been paying for Paramount+ but not getting it.
Message posted on 24 Jan 2026 01:37 PM
I managed to solve this.
I have Sky Stream, not Sky Q, but the solution may work.
Here is my post which describes everythign
Message posted on 24 Jan 2026 02:19 PM
@Martin+Cassidy wrote:I managed to solve this.
That's great, many thanks for writing up the process and sharing it!
I do not have a sig other than this message. SkyQ.
Enjoying HDR with 4k Blu-Ray, Amazon, YouTube and gaming since 2016.
Message posted on 02 Feb 2026 08:44 PM
I rang and asked them to fill in the CRF. They refused saying that it's just for a single customer issue and as it's affecting multiple users, and they are aware, the back-end (lol) team are working on a solution. They rang me back today, still not sorted, they're now ringing back in another 10 days. Not at all impressed. If they just filled the bloody form in, it would probably be sorted by now.
Message posted on 03 Mar 2026 10:00 PM
I have sky glass and sky cinema I have an issue where paramount plus won't sign in and says subscription has expired or paramount plus is not included in my subscription.
This worked until a couple of weeks ago
Message posted on 04 Mar 2026 12:22 AM
Hi this is exactly my problem and no one can help no Paramount plus for over a month now
Message posted on 04 Mar 2026 08:14 AM
Yep it worked then it didn't work says I our £24 when I haven't a clue where this has come from subscription has ran out can access anymore. Phoned sky and they said there's 0 to pay as I expected went through a load of stuff and yep still says there's same.
Now using my own account an guess what works perfectly first time.
