Discussion topic: PARAMOUNT PLUS RATINGS MESSAGE
This message was authored by: BiggYinn
Every time I watch anything on paramount plus I get the annoying ratings message on the top left of screen this is usually accompanied by slight buffering but the most annoying part it dimms the picture for the duration of the message plus an extra 5 seconds
,  what if anything will be done about this as its making rhe service practically unwatchable
Re: PARAMOUNT PLUS RATINGS MESSAGE
There is already a thread on this community discussing this issue here;
https://helpforum.sky.com/t5/Sky-Q/Age-restriction-warning-bar-on-Paramount-keeps-appearing/m-p/4343...
This message was authored by: CP2
The community posts about the paramount plus age restriction bar have all been removed.
Can anyone shed light on how to stop then coming up every 2 mins?
This message was authored by: ian04
Age restriction warning bar on Paramount +
it's extremely distracting as it causes the screen to darken for 5-10 seconds every few minutes. while the banner just sits there all the way through the programe.
is there a way to remove it, so as to be able to watch the programe without it being distrupted ?
This message was authored by: Gibson909
I downloaded Paramount plus tonight and during the film we chose to watch  we were constantly interrupted by the ratings message appearing.  The Sky forums have deleted these threads so it is impossible to get a simple answer - is there a fix or is this a glitch?  I turned off parental controls and performed a re-boot but still had the problem.
Wild Boar
There doesn't seem to be a solution.
I've seen one response is to do with the way sky delivers it to customers.
Too techie for me, but apparently if you watch it through apple TV or other services it doesn't have the same problem.
So we, as sky customers, are getting poor service but can't do anything about it!
This message was authored by: best+of+the+best
Fair comment @CP2 but not really noticed it whilst watching Paramount+ via Sky Q
Haven't noticed anything different using the Paramountplus app on my tv or FireTv stick
This message was authored by: Skynewbie92
This is a massive issue for me
Sky q 1tb main box rating banner appears twice in an hour. Sky q mini box every 30 seconds
Sky have had threads for years in this issue but still no resolve now all previous threads also seem to have been deleted
Steps I've taken to try resolve but to no avail
Factory reset both boxes
Direct connection to router via ethernet (500mbps broadband) both boxes
Force refresh all apps
Update both boxes to latest firmware
Disabled 2.4ghz wifi to force connection to 5ghz
Disabled 5ghz wifi to force connection via 2.4ghz
Signed out of paramount plus and re signed in on both boxes
This issue does not occur direct through app on lg tv or apple tv or via laptop only on sky q
Sky please help
This message was authored by: Julesy+T
Hi there,  had the exact same problem and it was driving me crazy. I found that if you turn off Auto-Play in the settings stopped it completely. Hope it helps.
Thankyou will give it a go tonight
This message was authored by: RFCTabs
Perfect answer. Stopped it right away. Thank you. 😊
Good stuff, glad to hear it.
This message was authored by: JW.Thomas
Just tried an unfortunately it didn't work.  Seems like a Sky issue, needs sorting considering half the stuff i used to watch is now on P+
