Discussion topic: Wire
Message posted on 16 Oct 2023 12:37 PM
Wire
I'm just changing tv units ... but my sky Q box wires go through the back of the cabinet through a hole I've taken out wires that I can .. but how do I remove
the two wires that are sat in 1 and sat in 2 as I can't remove them and don't know how
Message posted on 16 Oct 2023 12:44 PM
Re: Wire
You have to unscrew them. They should only be hand-tight.
Message posted on 16 Oct 2023 12:45 PM
Re: Wire
However if the dish feed cable was fed through with bare ends and then terminated, I guess it's possible that the F-connectors are too big to fit back through the hole.
