Discussion topic: P
This message was authored by: JN4
P
Had skyq installed a couple of weeks ago.Every time I try accessing the red button recap on sky sports for example,i get a blue screen saying" There is a technical issue.Please try again later" code WGT8. The red button never loads.
Re: P
hi @JN4
Does SKy Sports appear as an app
Home - apps
Also what happens if you select the (...) button to the right of the Home key  & select the SKy Sports App from there ?
Re: P
@JN4 I think sometimes refreshing the apps sorts this error message
you need to enter the engineers menu
To enter the engineers menu do the follow
press the home button then scroll down to setting and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
scroll down to apps > refresh
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for JN4
Level 2 icon
Re: P
I get the same technical issue message when I open the app from the home key.The sky sports app opens on the right of the screen. Why is the red button option/recap not working?
Re: P
hi @JN4
When you open the app from the (...) button do  you know if it is deifinitely the new SKY Sports app which typically starts with a list of live/upcoming Football & a left menu set of icons to take you to other sports ?
I suspect you are getting the old SKY SPorts app which had Results listings (I think) amongst other options
It may be that your Software & apps are not fully up to date
To check & refresh if needed follow all the steps on this link (skipping any that are OK):
Software / Apps update
Note after selecting the Refresh apps (as detailed later in that link) it may tae a little time for them to refresh
Avatar for JN4
Level 2 icon
Re: P
Yes. I have the old options. My teams,scores  & tables etc.
Re: P
@JN4  I suspected that might the reason - Please do follow the steps in the link I also gave
I think the problem you are getting with the red button is that it is trying to launch the new SKY Sports app that you don't have
Avatar for JN4
Level 2 icon
Re: P
Thank you. I am now refreshing my apps. Hopefully that will fix the issue.
Re: P
Is your software also Q270 ?
Avatar for JN4
Level 2 icon
Re: P
How would I find this? My apos have refreshed but I still have the old sky sports menu.
Re: P
Have you followed the link I posted ?
Avatar for JN4
Level 2 icon
Re: P
Software version is Q230
Re: P
Definitely out of date - as Q270 is th elatest & I think needed for the latest Sports App
As per the link
On the Home - Settings - System Info - Software Version -
Scroll right & select Setup  & Press Software Download
Re: P
BTW @JN4
Don't forget to do this on all boxes
Avatar for JN4
Level 2 icon
Re: P
I have downloaded to Q270 on the main box. Do I have to do this on all mini boxes for the update to work,as I still have the technical issue message showing and the old sky sports app on the main box.
