9
This discussion topic has been answered Discussion topic: Our sky box has stopped working
This message was authored by: Christopher41
Our sky box isn't working
Re: Our sky box has stopped working
@Christopher41 wrote:
nothing on the screen and the light is staying orange
Hi @Christopher41
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Hi @Christopher41
Exactly what is happening?
Is there any Onscreen message?
What colour is the Led on the front right of the Q box\?
Avatar for Christopher41
Level 0 icon
Level 0 icon
We just cant get it back on , weve tryed differents leads and nothing is bringing it back on
Hi @Christopher41
Level 0 icon
Thankyou it's come back on.,, but the volume on the remote stopped working
Level 0 icon
Even with new batteries
Level 0 icon
All working now !
This message was authored by: Nas34
We have a sky+HD box not a skyQ and the same problem is happening to us. The remote works as it can turn on the TV but the light remains orange on the sky box. We've turned it off many times but are unsure what to do.
This message was authored by: Mister_Dalek
Sky no longer support Sky+HD boxes so your options are to switch to Sky Q or source a replacement Sky+HD box from eBay or a refurbished box supplier. Amazon sell renewed +HD boxes for under £50.
You can just swap your cabling and viewing card over and carry on as you were.
