Discussion topic: Not working properly
This message was authored by SWEEPY-1 This message was authored by: SWEEPY-1
My sky is taking ages to load up, when I watch ytube it is cutting me off and I have to go back into it ,when I play a game on my devices it is very slow and I get better off that as well,I have to constantly turn the whole thing off to reboot it I pay £72 a month haven't got a lot for that and I would like to know when my contract is up since I am unable to speak to someone about this
Re: Not working properly
Hi @SWEEPY-1 .
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
Regarding your issue
This message was authored by MightyQuinn This message was authored by: MightyQuinn
Hi @SWEEPY-1   It is quick and easy to see when you are "in contract" to. Go to My Sky in the App or in the Sky web site. Click on Your Products and you should see "Offer ending" date(s).
