2
This discussion topic has been answered Discussion topic: Not turning on
This message was authored by: Luton+5
Not turning on
Not turning on. Screen message states when the screen goes blank press home to get started .
Re: Not turning on
Hi @Luton+5
Have you tried switching the Q box on using the Standby button on the front right of the Q box (the Amber led)?
If this brings the box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Re: Not turning on
Hi @Luton+5
Avatar for Luton+5
Re: Not turning on
Thanks oldfella sussed it now.
