Discussion topic: Mini box error MR104
This message was authored by: Beriha
Sky mini box not working satin error MR104
Moderator comments: edited title of thread
Re: James
@Beriha Have you tried rebooting your main Q box ie
then
doing the same with the mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Re: James
Hi @Beriha
If a reboot doesn't help try a Network Reset on the mini.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
