Discussion topic: No recordings
Message posted on 23 May 2023 12:34 PM
No recordings
Sky box works in all other aspects , but no recordings just a swirling please wait?
I've unplugged box and made no difference
Message posted on 23 May 2023 12:37 PM
Re: No recordings
Hi @Landy+lover
Message posted on 23 May 2023 12:48 PM
Re: No recordings
Reset and reconfigured the remote. Skybox on and working but still no recordings ? Squirling please wait still on recordings screen section
