Discussion topic: Not getting different channels
This message was authored by: Calcara
Many channels are unavailable
Re: Not getting different channels
@Calcara
What error message are you seeing?
Avatar for Calcara
Level 0 icon
@Calcara
Okay, when a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
It’s not necessarily something that will be visible to the naked eye and could only affect one or two channels. If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
