Discussion topic: Not connecting to internet
Message posted on 10 Dec 2023 10:37 AM
Re: Not connecting to internet
Message posted on 04 May 2024 12:56 AM
I have tired to reboot the router but and the internet sign appears on my device. However, there is no internet connection
Message posted on 24 Aug 2024 09:43 PM
We have this same issue! How did yours get resolved please? We have been all through the steps repeatedly and still no luck......
Message posted on 06 Sep 2024 09:30 AM
Exaact same problem here other than I have wired ethernet connections to both the Q and the Mini box.
No internet connection on both boxes and neither reconnects after trying all the above (other than wifi).
Message posted on 07 Sep 2024 05:29 PM
I have exactly the same problem; the internet is green on the Sky hub but, Q box has no connectivity. However, desktop, laptop etc are all connected. The problem started on Thursday 5th September. Does anyone have any suggestions?
Message posted on 21 Sep 2024 06:18 PM
I have same problem. Worked fine for months until the other night. Been through all the recommended resets, switched everything on off etc and just end up with a message saying I may have to get a Sky Q booster. My broadband is SKY
Message posted on 22 Sep 2024 03:31 PM
I had an issue connecting a new box to WiFi and tried all the normal suggestions to no avail.
While I was waiting for a replacement box I decided to look at the Sky Q router setup.
On the 2.4GHz WiFi Settings page, under WiFi Settings, there is a pull-down to select the Bandwidth. Mine was set to 40MHz. The alternative setting is 20MHz/40MHz. I selected this option, applied the new setting and retried the connection. It worked!
My previous box had no issue connecting with the previous settings.
Whether this was pure luck, I have no idea.
Can anyone explain why this would have made a difference?
Message posted on 24 Sep 2024 07:26 AM
Thanks, this worked for me too (although mine was set to 20)
Message posted on 24 Sep 2024 08:13 PM
I have exactly the same problem, it will not recognise my router, if you still owe money on your sky glass then it still belongs to Sky, that being the case they should fix it or replace it. Strange how this has not hit the news or the press but then again you only have to look at who owns Sky and also large numbers of media outlets and newspapers. Is there a connection.
Message posted on 27 Sep 2024 11:31 AM
I have a problem every day with my internet plugging and unplugging switching on and off. Mostly in the mornings but it works late at night. Do I have to change my password ?
Message posted on 24 Jan 2025 07:29 AM
How do you get to this page please? I have the same problem and have tried all the other suggestions.
Message posted on 24 Jan 2025 07:30 AM
The wifi setup page I mean
Message posted on 24 Jan 2025 08:06 AM
@thomas75 wrote:The wifi setup page I mean
Depends which router you have. Normally you just type the IP address of your router (shown as "gateway" on a computer's ip network settings) into the browser address bar. You will need to login so know the admin credentials for the router, and navigate its menu which varies by manufacturer/device.
Message posted on 07 Feb 2025 07:30 PM
I have exactly the same issue. Upgraded to full fibre BB with sky yesterday. Will not connect to my sky Q. Tried all steps as recommended still no luck
Message posted on 08 Feb 2025 09:49 AM
Thanks for escalating this. We’ve sent an @BOX12 invite to chat.
