4
This discussion topic has been answered Discussion topic: Noise from sky Q box
This message was authored by: Box.
My sky box is making a noise. Like a fan going around and  no tv working . I have unplugged the box
This message was authored by: PandJ2020 Answer
Re: Noise from sky Q box
They do make some noise and a fan will start if getting hot.
Are you saying it's wasn't showing a picture too?
Avatar for Box.
TV not getting a sky signal
If you've turned it back on and the TV is on the correct input then the box may have failed.
You'll need to call Sky for an engineer to check.
Follow the advice laid out in this Sky help article first and if at the end your problem still exists there is the ability to book an enginner visit via an online link.
Link to follow;
Sky Help | Sky.com
