Discussion topic: No u tube or voice activated links
Message posted on 16 Aug 2023 06:13 PM
I have the message up it looks like you do not have internet connection right now.
but I do have sports , etc. I have reset router numerous times. Shut everything down but nothing works.
put in my internet code numerous times but same message.
Message posted on 17 Aug 2023 11:00 AM
Re: No u tube or voice activated links
Message posted on 19 Aug 2023 11:03 AM
An invite was sent but there was no response within 48 hours so it has automatically closed.
If you still need help with this please let us know by posting on the forum again and we will get it escalated through to us.
Tom
Message posted on 19 Aug 2023 11:12 AM
Have you tried a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
