Discussion topic: No sk6
This message was authored by: RitaHuey
No sk6
My tv is telling me to insett my viewing card with the chip facing up.have not got a clue what this .
Re: No sk6
@RitaHuey
Looks like you didnt finish your post before sending it?
On a Sky Q box you will have a viewing card in the slot on the right side of your box. The card should be sticking out very slightly, If you push it gently in it should then pop out. Give the card a gentle wipe with a soft dry cloth, then push it back in with the chip again facing up.
Avatar for RitaHuey
Re: No sk6
I didnt sed the reply ,my friend told me the same thing.so thank you to the person for their help.
