Discussion topic: Connectivity issues
Message posted on 30 Dec 2025 07:33 PM
Connectivity issues
Ok I've posted about this 4 times now and even had an engineer out but it's still giving me the "there is a connectivity issue between your sky Q main box and mini box. O don't know what to do as the engineer refused to connect an Ethernet cable.
Message posted on 30 Dec 2025 07:37 PM
Re: Connectivity issues
Hi @Rosemary4
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router (not Sky Max) if on Sky Broadband or previously connected mini).
Message posted on 30 Dec 2025 09:52 PM
I've done all that many times and already have a Wi-Fi booster but it keeps happening.
Message posted on 30 Dec 2025 09:58 PM
Is that a Sky Q WiFi booster @Rosemary4
If so, then that completely changes the set up procedures.
Message posted on 31 Dec 2025 12:10 AM
Yes it is
Message posted on 31 Dec 2025 12:17 AM
When the engineer was out he said the problem was with the booster not getting a signal from the main box so he moved it to a different location but the problem is still happening. He also said it's the style of house we live in (old style granite)
