Discussion topic: No signal
Message posted on 28 Aug 2023 10:24 AM
No signal
Message posted on 28 Aug 2023 10:27 AM
Re: No signal
Message posted on 28 Aug 2023 10:30 AM
Re: No signal
@Bertie42 wrote:
Every channel was working except for sky channels . Sky sports etc
Hi @Bertie42
Check through the following link.
https://www.sky.com/help/articles/sky-tv-no-satellite-signal
If you cannot solve your issue best to contact Sky for an Engineer
Message posted on 28 Aug 2023 10:55 AM
Re: No signal
Message posted on 28 Aug 2023 10:57 AM
Re: No signal
Unfortunately that will be the earliest possible appointment based to engineer availability in your area.
Message posted on 28 Aug 2023 11:19 AM
Re: No signal
@Bertie42 wrote:
Tried for engineer . Best they can do is 4th of September which is not good enough.
A week is actually pretty good.
If your need is to have a faster response then look at Sky Protect.
However, they will normally apply a credit once the fault is fixed from the date of reporting if you contact them and ask.
Message posted on 28 Aug 2023 12:21 PM
Re: No signal
A sky engineer should be out today considering it was only installed on Saturday and has now failed . Certainly should not be a cost . I should be refunded as I couldn't watch any football over the weekend which I pay handsomely for
Message posted on 28 Aug 2023 12:23 PM
Re: No signal
The engineer visit will not cost you. As stated, the earliest possible date has been provided. The chances of a same day visit are a thing of the very distant past.
Message posted on 28 Aug 2023 12:28 PM
Re: No signal
@Bertie42 Regardless of when the system was fitted expecting an engineer next day or even same day is unrealistic, all engineers will already be on jobs already booked and would never be pulled off orther jobs to prioritise another customer, it's not how things work.
As for any refund (the few pence you'll get) will need to be discussed with Sky once service is restored.
Message posted on 28 Aug 2023 12:37 PM
Re: No signal
That's simply not good enough for a company the size of sky . Should have engineers on call for these problems. If I can't get an engineer until the 4th of September will I get refunded for loss of service for a week ?
Message posted on 28 Aug 2023 12:43 PM - last edited: 28 Aug 2023 12:46 PM
Re: No signal
That's simply not possible, not unless you wish your subscriptions to at least double? Having engineers on call out as you seem to expect is costly and that cost would need to be borne by other customers, which wouldn't be fair.
As already advised you'll need to discuss any refunds once your service is restored.
Message posted on 28 Aug 2023 12:45 PM
Re: No signal
Again, unrealistic if you expect a Sky engineer to sit around in each area of the UK just on the off chance a new customer encounters a problem.
As previously suggested that is something you'll have to discuss with Sky once the problem has been fixed but it would probably be a couple of pounds at most.
Message posted on 28 Aug 2023 12:49 PM
Re: No signal
I would expect my new install to work which it doesn't so engineer should come and fix the issue today . I don't think that's unreasonable. Different if it wasn't only installed on Saturday
Message posted on 28 Aug 2023 12:52 PM
Re: No signal
It has already been explained why that is unreasonable, unrealistic and not going to happen. Your visit has presumably been booked for next Monday so we can't advise you anything further.
Message posted on 28 Aug 2023 12:57 PM
Re: No signal
It hasn't been booked because that's too long of a wait . If I could actually get somebody on the phone it would be great. If I got a boiler installed and it didn't work you can be sure they would be back posthaste to fix it . Customer service is very poor from sky I have to say .
