Discussion topic: No signal
This message was authored by: Bertie42
No signal
Sky engineer installed a new sky q box on Saturday. My wife was there . When I got home engineer had gone. Every channel except any sky channel was not working . On Sunday none of the channels where working . Says no sattelite signal on screen
Avatar for Bertie42
Re: No signal
Every channel was working except for sky channels . Sky sports etc
Re: No signal
Hi @Bertie42
Check through the following link.
https://www.sky.com/help/articles/sky-tv-no-satellite-signal
If you cannot solve your issue best to contact Sky for an Engineer
Avatar for Bertie42
Re: No signal
Tried for engineer . Best they can do is 4th of September which is not good enough.
Re: No signal
@Bertie42
Unfortunately that will be the earliest possible appointment based to engineer availability in your area.
Re: No signal
A week is actually pretty good.
If your need is to have a faster response then look at Sky Protect.
However, they will normally apply a credit once the fault is fixed from the date of reporting if you contact them and ask.
Avatar for Bertie42
Re: No signal
A sky engineer should be out today considering it was only installed on Saturday and has now failed . Certainly should not be a cost . I should be refunded as I couldn't watch any football over the weekend which I pay handsomely for
Re: No signal
@Bertie42
The engineer visit will not cost you. As stated, the earliest possible date has been provided. The chances of a same day visit are a thing of the very distant past.
Re: No signal
@Bertie42  Regardless of when the system was fitted expecting an engineer next day or even same day is unrealistic, all engineers will already be on jobs already booked and would never be pulled off orther jobs to prioritise another customer, it's not how things work.
As for any refund (the few pence you'll get) will need to be discussed with Sky once service is restored.
Avatar for Bertie42
Re: No signal
That's simply not good enough for a company the size of sky . Should have engineers on call for these problems.  If I can't get an engineer until the 4th of September will I get refunded for loss of service for a week ?
Re: No signal
That's simply not possible, not unless you wish your subscriptions to at least double?  Having engineers on call out as you seem to  expect is costly and that cost would need to be borne by other customers, which wouldn't be fair.
As already advised you'll need to discuss any refunds once your service is restored.
Re: No signal
Again, unrealistic if you expect a Sky engineer to sit around in each area of the UK just on the off chance a new customer encounters a problem.
As previously suggested that is something you'll have to discuss with Sky once the problem has been fixed but it would probably be a couple of pounds at most.
Avatar for Bertie42
Re: No signal
I would expect my new install to work which it doesn't so engineer should come and fix the issue today . I don't think that's unreasonable. Different if it wasn't only installed on Saturday
Re: No signal
@Bertie42
It has already been explained why that is unreasonable, unrealistic and not going to happen. Your visit has presumably been booked for next Monday so we can't advise you anything further.
Avatar for Bertie42
Re: No signal
It hasn't been booked because that's too long of a wait . If I could actually get somebody on the phone it would be great.  If I got a boiler installed and it didn't work you can be sure they would be back posthaste to fix it . Customer service is very poor from sky I have to say .
