Discussion topic: No signal
This message was authored by Mark192 This message was authored by: Mark192
No signal
No signal... I've tried everything. WiFi is fine
This message was authored by Daniel0210 This message was authored by: Daniel0210
Re: No signal
@Mark192
”No signal” tends to be a message from your TV (in which case check the cables going to the TV). A “no satellite signal” message relates to your Sky box.
Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish (it’s not something that will necessarily be visible to the naked eye). If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
▪️I AM NOT A SKY EMPLOYEE (undercover or otherwise) ▪️
This message was authored by Laing1 This message was authored by: Laing1
Re: No signal
@Mark192 wrote:
No signal... I've tried everything. WiFi is fine/?
@Mark192 do you have Sky + HD Sky Q or Sky Glass/Stream ?
If you have Q or HD+ then is it no signal or no satellite signal ?
