Discussion topic: No signal
This message was authored by: Kevin1888
No signal
Hi I recently agreed to change my package to sky glass, however within 20 mins of confirmation of this and booking in for a next Wednesday, my signal looks to have been cut, I have my phone/broadband /apps, but no channels at all. And can't get through to someone to help. Can anyone here give me any assistance? Thanks in advance.
Re: No signal
@Kevin1888 what messages are you seeing on the screen.
It would be unusually for Sky to end your Q services before you receive Glass as, as soon as you activate your Glass TV(which cannot be done until you receive the TV) then your Q subscription is ended
LG 49SJ 810 V UHD TV, Google Pixel 10 Pro XL mobile
Avatar for Kevin1888
Re: No signal
No signal message on a blue screen for all channels
Re: No signal
Hi @Kevin1888   No signal is a technical error and not related to subscription. Perhaps it is just a coincidence.
Re: No signal
is that no signal ? or does the Q box start up and you get into the Q box and see the main Screen  but see a no satellite signal message ?
