Discussion topic: No satellite signal on Movies channels 301 to 311 - I am subscribed to Movies.
This message was authored by: Sandy66
Hi
I pay a subscription for SKY Movies, but I cannot watch any on channels 301 to 311 - I get the message "This channel is currently affected by a satellite signal problem."  But I can watch all the other SKY channels, Movies are the only channels affected.  Has anyone any ideas how this can be fixed before I have to pay for an Engineer to come out?  Many thanks.
Sandy
Castleford
Re: No satellite signal on Movies channels 301 to 311 - I am subscribed to Movies.
@Sandy66
If a message displays “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish. If it doesn’t you’ll need to contact Sky to book an engineer appointment which is free.
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
Avatar for Sandy66
Level 0 icon
Hi Daniel0120
Thanks for your quick reply, but, how can I be receiving the other Sky channels and not the movies if it is a dish alignment problem? Are Movie channels different to the others? Sorry, just trying to understand better. 🙂
All the Sky Cinema channels are broadcast on the same frequency and dish alignment faults typically only affect certain frequencies, meaning most channels still work fine. You will need an engineer visit to fix this.
Avatar for Sandy66
Level 0 icon
Thanks Daniel0210 and Xenon81 for your expertise and advice. I will get right on it! 😁👍
@Sandy66
As stated above
@Daniel0210 wrote:
@Sandy66
This message was authored by: Martin195
I have the same issue as of yesterday, all channels fine apart from movies 301-311
@Martin195
The previous advice will apply if you're seeing a message of no satellite signal.
Cheers, yeah thought it would be the case, communal dish so I'll have to chase the building maintenance folk
This message was authored by: Dave19682
Hi mine are down aswell it's likely to be a sky issues.
@Dave19682
It's likely to be a dish or LNB issue. See the advice above on post 2 which applies to you too.
I had mine replaced about 2 months ago for a similar issue.
@Dave19682
Then you'll need to get them back I'm afraid.
