Discussion topic: Mini box shutting down
Message posted on
10 Jul 2025
04:22 PM
- last edited:
11 Jul 2025
08:26 AM
by
SpaceSparkie
My sky a mini box keeps on shutting down . I can be watching sky tv or Netflix and it just shuts down and turns off. This happened 5 times last night . I rebooted and it still happened
only now started to do this
any ideas ?
Moderator Notes: Corrected title spelling
Message posted on 10 Jul 2025 07:23 PM
Re: Mini box **bleep**ting down
any ideas ?
Hi @Mufv1972
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
