Discussion topic: No satellite signal issue
Message posted on
31 Dec 2023
05:34 PM
- last edited:
04 Jan 2024
02:57 PM
by
Kelsingra
We have no satellite signal. Any suggestions how we can fix this?
Moderator note: Moved from nws article comments and changed title to reflect topic.
Message posted on 04 Jan 2024 02:58 PM
Re: Contacting Sky over the Festive Period - Social Media
@Gracie70
Is this still an issue? Your post has been moved to the correct board.
Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish (it’s not something that will necessarily be visible to the naked eye). If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
