Discussion topic: I need my Sky dish dish moved
This message was authored by: Tania+I
I need my Sky dish moved due to neighbur having extension built and blocking my signal .
Re: I need my Sky dish dish moved
@Tania+I  I'm not sure why you've posted this in the Glass/Stream firum.  I've moved your post to the Sky Q forum.
Give Sky a call @Tania+I There will be a charge of about £65.
edit: just to add, that will be dependent on there being a suitable position for it to be moved to.
This message was authored by: Invisiblename
@Tania+I  Or you could use a local independent aerial / dish installer which would probably be quicker
I am just another Sky customer!
This message was authored by: JeremyB
We are having an extension built at our house and have lost the signal as there is a new wall blocking the signal from the dish
@JeremyB
The above reply (post 3) applies to you too.
@JeremyB  or post 4 above
@JeremyB if you use an independant installer they need to put the dish at a height Sky can access it in case of future visits by Sky.
If the independant sites the dish too high then Sky installers can refuse to work on it due to Skys health and safety policy
So just something to bear in mind
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
