Discussion topic: No satellite signal been like it for five weeks
This message was authored by: Samanthapearcy2
Need someone to call me as my TV says no satellite signal been like it for 5 to 6 weeks
Re: No satellite signal been like it for five weeks
@Samanthapearcy2
No one can call you. This is a customer helps customer forum and you aren’t contacting Sky Customer Services on here.
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment so check the troubleshooting on this link
It’s worth noting that:
1 - a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels
2 - a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored.
5 weeks ago was Storm Éowyn I assume?
