Discussion topic: No red light on mini box
Message posted on 16 Nov 2024 01:18 PM
My minibox is lit up at the back but no lights at front and won't turn on.
Tried the usual reset and unplugging but red light comes on for a couple of seconds then goes off.
Message posted on 16 Nov 2024 01:26 PM
Re: No red light on mini box
As you've mentioned it's a mini box I've moved your post to the Sky Q board.
Try a reboot of the main Sky Q box first, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Message posted on 16 Nov 2024 01:49 PM
Thanks for the advice.
just tried that, my second box is still in the same state. Unresponsive
