Discussion topic: No power cable with replacement
Message posted on 23 Aug 2024 06:07 PM
I have an order of a new box today but it came without a power cable,
Message posted on 23 Aug 2024 06:41 PM - last edited: 23 Aug 2024 06:41 PM
Re: No power cable with replacement
Depending which version Q box you have @Andy2891
If it is the Qbox without a separate power supply then it's a just a standard Power cable. These re readily available at various lengths from High Street stores or internet . It's a IEC C7 (figure of eight power lead)
however it it is the box which requires a separate power supply then yo need to contact Sky directly.
Message posted on 23 Aug 2024 06:51 PM - last edited: 23 Aug 2024 06:52 PM
Hi @Andy2891 If it is an ES240 box your only choice is another box swap. To play safe swap everything (apart from your viewing card, keep that).
