Discussion topic: Sky mini box keeps loosing connection
Message posted on 23 Aug 2024 06:14 PM
My sky mini box has had to be reset 4 times this week.
today it showed an error message stating I needed to upgrade my subscription to view recorded shows.
Message posted on 23 Aug 2024 06:18 PM
Re: Sky mini box keeps loosing connection
@TiggerTigger66 Have you tried rebooting your main Q box ie
then
reboot your mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 23 Aug 2024 06:30 PM
I have done that every time before I reset the mini box
Message posted on 23 Aug 2024 06:44 PM
Have you successfully performed a Network Reset on the mini.
