Discussion topic: No picture
This message was authored by: Summerlea
No picture
There is a message on the tv saying no signal, sound is fine as is the other tv in the kitchen
Avatar for Summerlea
Re: No picture
Help!, there is no picture on the tv, the sound is working okay as is the tv in the kitchen, have checked all connections and they are fine
Re: No picture
Hi @Summerlea
With the SKY Q box on  try pressing the following keys in sequence
Home 1 0 8 0 Home
Re: No picture
Hi @Summerlea
Try a Reset Settings in the main Q box hidden menu.
