Discussion topic: No picture
Message posted on 28 Jun 2023 05:36 PM
No picture
There is a message on the tv saying no signal, sound is fine as is the other tv in the kitchen
Message posted on 28 Jun 2023 05:41 PM
Re: No picture
Help!, there is no picture on the tv, the sound is working okay as is the tv in the kitchen, have checked all connections and they are fine
Message posted on 28 Jun 2023 06:24 PM
Re: No picture
Message posted on 28 Jun 2023 06:30 PM - last edited: 28 Jun 2023 06:31 PM
Re: No picture
Hi @Summerlea
Try a Reset Settings in the main Q box hidden menu.
