7
Discussion topic: No internet results in sky q not turning on at all
This message was authored by ChristinaVF This message was authored by: ChristinaVF
We currently don't have internet. It has gone down in my area. No problems I thought I'd just watch TV on my sky Q box. As we have a dish.
Turning on the sky box it comes up with the message 'you will be ready to go in a few minutes ' then asks me to press home when the screen goes black.
Follow the instructions and sometimes it'll show live TV in the top left corner for a few seconds then it moves around the screen and then turns off . Starts the cycle again.
Surely I can watch satalite TV without the internet? Understand that I can on demand won't be available but I can't even watch BBC 1?
What is the point of the satalite dish on the side of my house if it's coming through the internet all the time?
This message was authored by nigea99 This message was authored by: nigea99 Answer
Re: No internet results in sky q not turning on at all
hi @ChristinaVF
You should be able to watch Satellite TV if there is no internet.
However, I think you are experiencing a bug that seems to affect some people with internet problems.
Whilst you have connection problems to the internet can you try turning off your router & see if that allows your box to start up without shutting down afterwards
This message was authored by Quoman7 This message was authored by: Quoman7
Hi @ChristinaVF Try rebooting your main SKYQ box by turning the power off at the socket for 30 sec then turn back on to reboot?
hi @ChristinaVF
ChristinaVF
Yes unplugged for several minutes. Same thing happens.
ChristinaVF
Hi @nigea99 I'll try turning off my router and see if that will bypass the bug. I'll let you know in a few minutes
ChristinaVF
Thanks @nigea99 I turned off the router and sky worked. Hopefully I will get internet back soon too! Thanks again 👍
Great news.
I am really glad you mentioned the moving around the screen, as it was that symptom that helped me think of this particular bug.
I think it should be OK once the internet is fully back working (fingers crossed)
@ChristinaVF please may we ask who is your internet provider ?
Knowing this may help the tech teams at SKY narrow down any problematical areas
P.S. Hope your internet is now working OK
