Discussion topic: Sky Q mini Box keeps freezing
This message was authored by: artherdaily
so we have had our Sky Q mini box for 5 years with no real issues
but recently it is starting to play up
the remote stops working
the box freezes on one channel
the picture disappears
and the only way to resolve this is to unplug the box and then plug it back in
this is now getting to be a daily issue
what do we do
thanks
Re: Sky Q mini Box keeps freezing
what do we do
thanks
Hi @artherdaily Try resetting your Mini box:-
Hold down the Reset button on the back of the Sky Q Mini box and switch it back on at the mains. Keep holding it until the light on the front flashes red and green. This will take about 30 seconds. Once it flashes red and green, press the standby button on the front of the box.
Avatar for artherdaily
ill give that a try and let you know
