Discussion topic: No internet connection Sky Q
This message was authored by: Helen237
I have no internet connection message on sky q. All lights are green on router. Have turned off 3 times and pressed reset button but still not working. Help!
Re: No internet connection Sky Q
Is your Q box connected normally via WiFi?
Who is your broadband with? Have you also power cycled the router itself?
sky Q 2 TB | sky Q Mini | sky Mobile | EE Full Works FTTC | LG B6 OLED | SONOS Beam 2
Avatar for Helen237
I have sky broadband
