Discussion topic: Remote
Message posted on 20 May 2025 09:00 PM
Remote
Message posted on 20 May 2025 09:15 PM
Re: Remote
@Hodnett wrote:
My sky q remote has stopped working
Hi @Hodnett
First make sure that you have new batteries.
Then with the Q box on with green led try completly resetting your Bluetooth remote.
Failing this Check the following link and it will lead to a form for a replacement remote.
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment
In the meantime if you have an Apple device with Sky Go you can set up a virtual remote to control your Q boxes.
See following link.
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
