This discussion topic has been answered Discussion topic: No TV Schedule beyond 5 days ahead
Message posted on 01 Nov 2025 02:56 PM
I noticed this yesterday when trying to set a recording for next Thursday (31/10 for 6/11). The TV guide was fine until Thursday when it stuck on "Waiting for TV Schedule". Same today (1/11) and both the main Q box and the minis were the same. Rebooted the main Q box (only) and the guide then showed Thursday, but Friday and Saturday (the part that was available) were again "Waiting for Schedule" - same on the Mini boxes.
Software is Q330.000.09.00L (63yh6DG)
Anyone having the same problem?
Message posted on 01 Nov 2025 03:55 PM
It may be worth rebooting your router then reboot the Sky Q equipment.
So reboot the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
Message posted on 01 Nov 2025 03:01 PM
							Re: No TV Schedule beyond 5 days ahead
@jblink there's nothing customers can do but wait for the epg to fully populate
this situation does occur occasionally
Message posted on 01 Nov 2025 03:49 PM
Thanks for this. This has never happened before, funnily enough, in the many years I have had Q or indeed the 20 ish years with plus type boxes. It has always been "all or nothing"
Message posted on 01 Nov 2025 07:06 PM
Many thanks. There is a reason I have the Q box on a separate switched socket from all the other kit (tv, Ethernet switch, WiFi access point, amp, Blu Ray, etc)! TV guide has now repopulated through to next Saturday. I guess the root cause of the subject issue is my impatience. Hey, ho!
