Discussion topic: No Hard Disk message.
This message was authored by: Marric1
Instruction for reset is go to settings, press 0.0.1 but dont  understand. how to do this .
Re: No Hard Disk message.
@Marric1
Try following the link below it should lead to a replacement box if needed…
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
This message was authored by: RK17
Done it and it still says no hard disk
Then it's likely to be kaputt and you'll have to call Sky to replace it.
This message was authored by: Invisiblename
That'll be "replace the Sky Q box" not just the hard drive.  The replacement will be delivered via a courier doorstep swap.  Make sure you remove your viewing card from the old box & take ALL the items out of the delivery box (the power supply may be different)
I am just another Sky customer!
Good point 😁
