Discussion topic: No Hard Disk message.
Message posted on 06 Feb 2025 03:10 PM
Instruction for reset is go to settings, press 0.0.1 but dont understand. how to do this .
Message posted on 06 Feb 2025 03:22 PM
Re: No Hard Disk message.
Try following the link below it should lead to a replacement box if needed…
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Message posted on 11 Feb 2025 11:27 AM
Done it and it still says no hard disk
Message posted on 11 Feb 2025 12:01 PM
@RK17 wrote:Done it and it still says no hard disk
Then it's likely to be kaputt and you'll have to call Sky to replace it.
Message posted on 11 Feb 2025 12:04 PM
That'll be "replace the Sky Q box" not just the hard drive. The replacement will be delivered via a courier doorstep swap. Make sure you remove your viewing card from the old box & take ALL the items out of the delivery box (the power supply may be different)
Message posted on 11 Feb 2025 12:09 PM
@Invisiblename wrote:That'll be "replace the Sky Q box" not just the hard drive.
Good point 😁
