Discussion topic: New box
This message was authored by: Kay33
New box
Hi I am getting a new sky box delivered as mine isn't working it says have the other item ready for a speedy exchange with your driver.. guessing this means I've to give them the old box??
Re: New box
Yes for sure @Kay33
Make sure you remove and keep the viewing card for the replacement if it is the main Q box.
Avatar for Kay33
Re: New box
Thanks he didn't mention giving the box back on the phone  so wasn't sure. No clue what I'm doing haha
Avatar for Kay33
Re: New box
Sorry another question do I give them the wires etc too or just the box? No idea if I get new ones lol
Re: New box
Don't worry about the wires @Kay33 .
You could make sure the replacement includes a remote control.  If not just keep the one you have.
Avatar for Kay33
Re: New box
Thanks. Oh I don't have the box it came in either do I just hand them it lol? Sorry never had this issue before
Re: New box
@Kay33
The DPD driver will take the new box out of its packaging and put the faulty box in the same packaging.
▪️I AM NOT A SKY EMPLOYEE (undercover or otherwise) ▪️
Re: New box
Hi @Kay33
Just have the old box ready when they deliver the new one.
Its a doorstep swap so take the new one out of the box and put in your faulty one.
The deliver should wat while you swap the Q boxes.
Avatar for Kay33
Re: New box
Great thanks
Avatar for Kay33
Re: New box
Thanks for the help
Re: New box
@Kay33
One thing to note - if your box is a 2TB box.
Some 2TB boxes need a separate power supply so before the driver leaves make sure you check the power socket on the back of the replacement & if it has a round multipin connector rather than a figure of 8 connection, make sure there is the separate power supply with it - we have seen a few posts where customers have only realised they need this after the driver has left.
Avatar for Kay33
Re: New box
Oh no that makes it more confusing hahah. Thankyou
