Discussion topic: New Sky Q box not supported.
Message posted on 16 Oct 2025 03:06 PM
Just received a new Sky Q box. All plugged in and set up yesterday. Today I have a screen on my Samsung TV that says: HDMI 1 Mode Not Supported. Resolution not supported. Change the Resolution of the external device. No idea what this means or why it has appeared today. Anyone help please?
Message posted on 16 Oct 2025 03:09 PM
Re: New Sky Q box not supported.
hi @JJT1
With the SKY Q box on (Green Led lit) try pressing the following keys on your SKY Q remote in sequence
Home 1 0 8 0 Home
this should change the SKY Q box to the universally supported 1080 resolution which should allow you to watch and change in menus
If you then want to change to 4K, you may need to change settings in your TV's Picture or HDMI menus
Message posted on 16 Oct 2025 03:13 PM
No, that hasn't worked. Nothing has happened. When I go to source on my tv it doesn't recognise the sky box at all. As if it is not connected. I tried a manual set up but the TV just doesn't recognise the box. This is a replacement box as the last one stopped working properly.
Message posted on 16 Oct 2025 03:16 PM
hi @JJT1
If you haven't already tried, try taking out the HDMI cable at both ends and re-seating it (or if you have one use a different HDMI cable)
Message posted on 16 Oct 2025 03:19 PM
I have done that. I have basically tried everything possible. There obviously isn't an answer so I guess I'll have to try a new box again.
Message posted on 16 Oct 2025 03:25 PM
Message posted on 16 Oct 2025 03:46 PM
Thanks for your help. I ended up phoning Sky and apparently it will work now. We'll see! 😜
