Discussion topic: Wi-Fi poor with mini box
This message was authored by: Nickeva67
I have Sky Broadband, Sky Q and 3x Sky mini boxes all connected with ethernet cables.
I thought the mini boxes acted as a Wi-Fi boosters?
One of the boxes is in the bedroom and the Wi-Fi is pretty poor.
Is there a way to check if the mini box is actually boosting the Wi-Fi?
Re: Wi-Fi poor with mini box
Hi @Nickeva67
For the best connectivity when all Q boxes are connected by Ethernet to your Router,   it is preferable to turn off all Q box WiFi. This then guarantees a stable Ethernet connection.
However turning off any Q box WiFi will also turn off it's Hotspot.
You can check if the WiFi is on or off in any Q box (main or mini) by going into the boxes hidden menu.
With Settings highlighted press 0 0 1 select.
Go to Network to check state of WiFi.
