14
This discussion topic has been answered Discussion topic: Network connection
This message was authored by: weezel
Network connection
Sky q keeps losing network connection since sky broadband upgrade
Re: Network connection
@weezel wrote:
After I've set it as 3rd party I assume
Yes correct @weezel
Hi @weezel
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Avatar for weezel
Level 2 icon
A third party router..sounds mad...the wps always works but it drops out daily..many times more than once
Afraid that's the issue if you have a Sky Max router @weezel
Avatar for weezel
Level 2 icon
How..in the settings when it asks if u have sky broadband?
Hi @weezel
It's because the White Sky Max fibre  router does not function like the normal Sky router and so if you want it to connect to your Q box reliably you need to connect it as if it is a third party router.
Avatar for weezel
Level 2 icon
Maybe that's why my mini box never connects for more than a few mins....I connect that then both lose connection
Yes that's likely correct @weezel
With minis you cannot connect them to the Max router.   You need to connect them by WPS to the main q box.
Avatar for weezel
Level 2 icon
Yes correct @weezel
Avatar for weezel
Level 2 icon
Thanks for your help...I hope it works
Avatar for weezel
Level 2 icon
It won't let me connect to a 3rd party as it knows its a sky max hub
Avatar for weezel
Level 2 icon
It says select wifi network and obviously 1 is sky and then there are a few others...neighbours etc
Avatar for weezel
Level 2 icon
Picked sky and had to enter password...
Avatar for weezel
Level 2 icon
Still lose connection..can have either 1 of the boxes on but when I connect both they both lose connection
