24 May 2024 04:48 PM
When I go through the apps onto Netflix, it appears to load as usual. I select my name as 'who's watching' to run Netflix goes back to the apps screen and doesn't load
24 May 2024 04:50 PM
Hi @Jayne0307
Have you first tried rebooting your Q box?
24 May 2024 05:03 PM
Hi. Yes, rebooting was my first thought, but it hasn't resolved the problem. I can log in on another device but not through the Q box
24 May 2024 05:08 PM
Two things you can try @Jayne0307
First is a reset settings onthe Q box.
Second is to refresh the Apps.
Both options are in the Q box hidden menu.
As Apps refresh can take a while probably best to try the Reset settings first.
24 May 2024 06:28 PM
👍Thanks very much for the hints. I'll give it a go tomorrow. Fingers crossed 🤞🤞
