7
This discussion topic has been answered Discussion topic: Sky Q keeps going to chanel 777 no matter what remote buttons i press, tv and box turns on.
This message was authored by: mcfc11
Turned on and off several times, rebooted, home aspects appear, channel picked, no sound, then no matter what button is pressed number 7 comes up then try another butto naother 7 comes up and finally the third 7 for that chanel which is islam channel for donations again with no sound any help appreciated.
This message was authored by: nigea99 Answer
Re: Sky Q keeps going to chanel 777 no matter what remote buttons i press, tv and box turns on.
hi @mcfc11
It sounds like your 7 key on the remote might be sticking
May I suggest you try seeing if you can free it
hi @mcfc11
This message was authored by: RCT1
Hi did you find an answer for this as ours keeps doing this exact thing?
@RCT1
So have you tried the advice in the post immediately above yours?
I have yeah. Switched off loads, reset, reset remote and changed batteries etc
The Post answer does not mention reboots, resets or batteries @RCT1
it specifically says your 7 key on the remote might be sticking.
Your original post asks if @mcfc11 found an answer.
@mcfc11 marked the answer in the thread.
Sorry if I wasn't specific enough I have also checked the key is not sticking.
@RCT1
After checking the basics if your Sky Q remote is definitely broken/faulty, if you follow this link it should allow you to do some more troubleshooting and then it’ll send you to a form to request a replacement (apparently this is not available to customers in the ROI).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
It may be quicker to purchase a new remote from a retailer or larger supermarket. If you do that as well as the above you’ll have a spare.
