Discussion topic: Netflix not working on multi room boxes
Message posted on 03 Oct 2023 03:22 PM
Nextflix works fine on main sky q box but when wanting to watch in another room on multi room it just comes up as Netflix and a whirling circle any ideas
Message posted on 03 Oct 2023 03:28 PM
Re: Netflix not working on multi room boxes
That probably suggests there's not enough bandwidth (particularly over WiFi) : Netflix tries to use a higher bitrate than Sky content to a Q Mini box.
Message posted on 03 Oct 2023 03:42 PM
@TimmyBGood Thank you, my issue is it was working fine up until around four weeks ago
Message posted on 07 Dec 2023 06:30 PM
Did anyone get a resolution to this? Mines doing the same now 😞
Message posted on 07 Dec 2023 06:32 PM
@Manob wrote:Did anyone get a resolution to this? Mines doing the same now 😞
If it's only the mini boxes then that's most probably a connection issue.
Message posted on 07 Dec 2023 06:44 PM
Yes only on the mini box. We can't get Sky broadband but we have a separate professional WiFi system so that's all good. Sky Q is wireless to one mini box then from that box to the next is hard wired and it's the one at the end of that wire not working? Any help and technophobe instructions would be really helpful. Thanks for the response 😉
Message posted on 07 Dec 2023 07:23 PM
Might be the same as the generic "netflix spinny circle problem" in the other 2 big threads. That can happen on any box I think.
Message posted on 03 Jan 2024 10:15 PM
Other apps working but Netflix comes up with the spinning wheel and just keeps going round. I tried to be the settings 001 to refresh , as that was working last year but that's now not being up the refresh option
Message posted on 04 Jan 2024 09:59 AM
Try the suggestion in the answer post in this thread
https://helpforum.sky.com/t5/Sky-Q/Netflix-Won-t-Load-Spinning-Circle/td-p/4327487
Message posted on 11 Mar 2024 08:37 PM
To fix this, i signed into netflix desktop and force a 'sign out' from the sky box device in question,
Then unplug the sky box and turn it back on again, after a minute.
Log into netflix as normal via the sky box menu and the app will begin to spin the wheel again but suddenly change back to the 'select user' menu which is where it then works as expected again,
Message posted on 11 Mar 2024 11:44 PM
Yes as per my post above yours. Seems to work for most people.
Why it's even needed is a mystery.
Message posted on 28 Aug 2024 10:43 AM
It's fine on sky box. The issue is with the multi room mini box. Nothing wrong with Internet connection.
Message posted on 29 Aug 2024 10:55 AM
@Stiffi wrote:It's fine on sky box. The issue is with the multi room mini box. Nothing wrong with Internet connection.
The netflix problem can affect each box randomly even if the others are fine.
