3
This discussion topic has been answered Discussion topic: Netflix Disney +
This message was authored by: Jimhol1
Netflix Disney +
Just received my box today but no Netflix or Disney + as promised
This message was authored by: nigea99 Answer
Re: Netflix Disney +
hi @Jimhol1
Chances are that the software & apps are not fully up to date :
To check & refresh if needed follow all the steps on this link (skipping any that are OK):
https://www.sky.com/help/articles/apps-on-sky-q-and-glass-basic-checks
Please note that the step to refresh apps often does not action immediately and may take several hours before it does
You can't find the apps?  Or something else?
hi @Jimhol1
Which box did you receive? Was a Sky Q box installed or were you sent a Sky Stream puck to install yourself? Or did you get a replacement Sky Q box for one that was faulty?
Does your subscription include Ultimate TV? You won't get Netflix or Disney+ included if you don't have this package.
